Datasheet Toshiba TC35681IFTG-002 — Даташит
ПроизводительToshiba
СерияTC35681IFTG-002
МодельTC35681IFTG-002
ARM® Cortex®-M0 / RF analog circuitry / DC-DC converter / LDO regulator / low power mode(4 level). Bluetooth® IC
TC35681IFTG-002 Data sheet/English
PDF, 1.6 Мб, Язык: анг., Файл опубликован: окт 2018
Статус продуктаUnder development
Код корпуса производителяP-VQFN40-0606-0.50-002
Automotive Supportда
Bluetooth CategoryBluetooth® low energy
Bluetooth Core spec.5.0
Current Consumption in Deep Sleep mode [(3.0V)]0.05 μA
Current Consumption in RX Active mode (peak) [(3.0V, 1Mbps)]5.1 мА
Current Consumption in Sleep mode2.5 μA
Current Consumption in TX Active mode (peak) [(3.0V, TX +8dBm, 1Mbps)]11.3 мА
Current Consumption in TX Active mode (peak) [(3.0V, TX 0dBm, 1Mbps)]5.2 мА
Embedded ProfilesGATT / SMP
Основные особенностиAutomotive / All data rates including 2Mbps specified in Bluetooth 5 / Long Range communication / Low power consumption / High temperature operation / Standalone mode support / LE Data Length Extension support / LE Secure Connection supoort
FunctionARM® Cortex®-M0 / RF analog circuitry / DC-DC converter / LDO regulator / low power mode(4 level)
InterfacingI2C (2 ch) / SPI (2 ch) / UART (2 ch) / PWM (4 ch) / ADC (5 ch) / SWD (1 ch)
Operating Temperature (Max)125 ℃
Operating Temperature (Min)-40 ℃
Other FunctionsLE 2M PHY / LE Coded PHY / LE Advertising Extensions / LE Channel Selection Algorithm #2 / LE secure connection / Random Number Generator
Power supply voltage (Max)3.6 В
Power supply voltage (Min)1.8 В
Receiver Sensitivity [(at 125kbps)]-105.2 dBm
Receiver Sensitivity [(at 1Mbps)]-95.6 dBm
Transmit Power(Max)8 dBm
Transmit Power(Min)-20 dBm
User Flash Size (KB)N/A
User RAM Size (KB)76
RoHSPlease contact us.
  • Wireless Communications Equipment ICs > Bluetooth® wireless communication IC
TC35681IFTG002, TC35681IFTG 002
На английском языке: Datasheet Toshiba TC35681IFTG-002
